Passos das roscas
Passos das roscas
Mensagem  sim_ou_nao em Qui Mar 25, 2010 10:13 pm
Passos ou passes?! Também não interessa, o que interessa é a informação Laughing
Retirei isto de um forum inglês por isso não me responsabilizo se não estiver correcto king
Se alguém quiser confirmar e traduzir eu agradeço desde já...
Timing Cover
5 x Bolts Cap Head 5/16"UNF (3/4" Long)
6 x Bolts Cap Head 1/4"UNF (7/16" Long)
5 x Washers 5/16"PLN (5/8" OD)
5 x Washers 5/16"SPR (1/2" OD)
6 x Washers 1/4"PLN (9/16" OD)
6 x Washers 1/4"SPR (7/16" OD)
1 x Nut 5/16"UNF (1/2" Head)
1 x Nut 1/4"UNF (7/16" Head)
Coolant Circui
2 x Bolts Heater Tap 1/4" UNF (7/16" Head, 1/2" Long)
2 x Washers Heater Tap 1/4" SPR (3/8" OD)
2 x Bolts Radiator Top 1/4" UNF (7/16" Head, 1 1/2" Long)
2 x Washers Radiator Top 1/4"PLN (9/16" OD)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 2" Long)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 1" Long)
4 x Washers (Water Pump) 5/16"PLN (5/8" OD)
4 x Washers (Water Pump) 5/16"SPR (1/2" OD)
Thermostat (Short)
3 x Bolts 5/16 UNC (1/2" Head, 1 1/2" Long)
3 x Washers 5/16" SPR (1/2" OD)
Engine Electrical
2 x Bolts (Alt' top) 5/16"UNF (1/2" Head, 2" Long)
1 x Bolt (Alt' Bottom) M8x20
1 x Nut (Alt' Bottom) mate NyLoc
4 x Washers (Alternator) 5/16"PLN (5/8" OD)
4 x Washers (Alternator) 5/16"SPR (1/2" OD)
2 x Nuts (Alternator) 5/16"UNF (1/2" Head)
2 x Bolts Starter Motor 3/8"UNC (9/16" Head, 1 1/4" Long)
2 x Washers Starter motor 3/8"SPR (5/16" OD)
1 x Bolt (A+ Distributor) 5/16" UNF (1/2" Head, 3/4" Long)
Clutch Slave (Non verto)
2 x Bolts (Cyl Mount) 3/8"UNC (9/16" Head, 1" Long)
2 x Washers (Cyl Mount) 3/8"SPR (5/8" OD)
1 x Bolt (Arm Stop) 1/4"UNF (7/16" Head, 1" Long)
1 x Lock Nut (Arm Stop) 1/4"UNF (7/16" Head)
Clutch Cover
8 x Bolts 5/16"UNC (1/2" Head, 1" Long)
8 x Washers 5/16"SPR (1/2" OD)
8 x Washers 5/16"PLN (5/8" OD)
Tappet Chest
2 x Bolts 5/16" UNF (1/2" Head, 1 1/4" long)
2 x Washers 5/16 PLN (5/8" OD)
Pre A+ Distributor Drive
1x Bolt 1/4"UNF (7/16" Head, 3/4" long)
1x Washer 1/4"SPR (3/8" OD)
Fuel Pump 2 x Bolt 5/16" UNC (1/2 Head , 1 1/2"long)
2 x Washers 5/16" SPR (1/2" OD)
2 x Washers 5/16" PLN (5/8" OD)
Oil Filter Housing
2 x Bolt 3/8" UNC (9/16" Head, 1" Long)
2 x Washers 3/8" SPR
2 x Washers 3/8"PLN (15/16" OD)
Manifold Bolts
6 x Bolt 5/16 UNF (1" Long)
6 x Washers 5/16" SPR (1/2" OD)
6 x Washers 5/16" PLN (5/8" OD)
Re: Passos das roscas
Mensagem  Nunotdi em Qui Mar 25, 2010 11:38 pm
o Pedro encontra cada coisa bom
Mensagem  Broa em Sex Mar 26, 2010 12:33 pm
Muito bom Pedro, já precisei disto muita fez...
Broa
Data de inscrição : 02/05/2009
Mensagem  bicho em Sex Abr 09, 2010 2:30 pm
Tradução
TPI - Threads per inch - fios de rosca por polegada
Diametro (imperial) fios de rosca por polegada Diametro (metrico)
polegadaspasso de rosca UNCPasso de rosca UNFmm
1/420286.3500
5/1618247.9375
3/816249.5250
7/16142011.1125
1/2132012.7000
9/16121814.2875
5/8111815.8750
3/4101619.05
7/891422.2250
181425.4
bolt - parafuso (head - cabeça, long - comprimento)
washer - anilha (PLN - chapa, SPR - mola)
nut - porca
ex
2x parafusos torneira aquecimento - 6.35 mm 28 fios de rosca (cabeça 11.11 mm, comprimento - 12.7 mm)
bicho
http://www.pedrocoelho.xyz
Mensagem  manumini em Qui Abr 15, 2010 10:36 am
boas pessoal.
eu tenho la por casa umas folhas com tudo isso.
estou num curso de mecatronica e como tbm tenho de tornear, frezar ... tenho la algumas tabelas.
vou digitaliza-las e posta-las aqui. estao muito claras e muito elaboradas.
têm passos de rosca, diametros da broca indicado para furar...
espero que ajude. é bastante util
manumini
Data de inscrição : 14/04/2010
Idade : 27
Mensagem  LuisPereira em Qui Abr 15, 2010 11:05 am
manumini escreveu:boas pessoal.
entao ja temos aqui um gajo pra nos rectificar peças a bom preço Twisted Evil
Mensagem  manumini em Seg Abr 19, 2010 11:11 am
LuisPereira escreveu:
seria com todo o prazer mas falta-me o torno em casa.
costumo levar para a escola e faço nos tempos livres. lol!
manumini
Idade : 27
Mensagem  M Bento Amaral em Seg Abr 19, 2010 9:48 pm
boa... a ver este topico... lembrei-me... o mini é ingles... os ingleses tem um triliao de passos de rosca... o mini vem com passos ingleses? Ja não quero o mini..... Sad
Razz
Razz
Razz
M Bento Amaral
Data de inscrição : 16/02/2010
Mensagem  LuisPereira em Seg Abr 19, 2010 9:51 pm
Fonix eu em certos sitios parti parafusos, furei e fiz rosca normal Twisted Evil
Mensagem  M Bento Amaral em Seg Abr 19, 2010 9:56 pm
E sabes quais são agora os sitos que tem rosca normal e rosca fina? =x
M Bento Amaral
Mensagem  LuisPereira em Seg Abr 19, 2010 10:49 pm
M Bento Amaral escreveu:E sabes quais são agora os sitos que tem rosca normal e rosca fina? =x
Pra que?
Qdo sairem voltam a entrar, se partirem passo o macho nas outras, é facil Razz
Mensagem  Xpto em Ter Jun 22, 2010 12:30 am
por acaso ando á nora com isto dos passos... isso se eu chegar a uma casa de parafusos eles percebem isso é que para mim isso é chines Very Happy Very Happy
já agora os parafusos do plafonier também são desses?? tou a ficar com vontade de por uns autoroscantes não tarda Evil or Very Mad
Data de inscrição : 22/01/2010
http://www.colonialdocas.com
Mensagem  M Bento Amaral em Ter Jun 22, 2010 6:29 am
Xpto escreveu:por acaso ando á nora com isto dos passos... isso se eu chegar a uma casa de parafusos eles percebem isso é que para mim isso é chines Very Happy Very Happy
Se for um gajo novo no ramo tás lixado... Mad LOL
Eu trabalho numa casa do genero a pouco tempo, e quando me aparecem la a pedir roscas maroscas até dou cabeçadas... lol e em polegadas nem comento! Very Happy Very Happy
M Bento Amaral
