Passos das roscas
+4
bicho
Broa
8 participantes
Passos das roscas
Passos ou passes?! Também não interessa, o que interessa é a informação
Retirei isto de um forum inglês por isso não me responsabilizo se não estiver correcto
Se alguém quiser confirmar e traduzir eu agradeço desde já...
Timing Cover
5 x Bolts Cap Head 5/16"UNF (3/4" Long)
6 x Bolts Cap Head 1/4"UNF (7/16" Long)
5 x Washers 5/16"PLN (5/8" OD)
5 x Washers 5/16"SPR (1/2" OD)
6 x Washers 1/4"PLN (9/16" OD)
6 x Washers 1/4"SPR (7/16" OD)
1 x Nut 5/16"UNF (1/2" Head)
1 x Nut 1/4"UNF (7/16" Head)
Coolant Circui
2 x Bolts Heater Tap 1/4" UNF (7/16" Head, 1/2" Long)
2 x Washers Heater Tap 1/4" SPR (3/8" OD)
2 x Bolts Radiator Top 1/4" UNF (7/16" Head, 1 1/2" Long)
2 x Washers Radiator Top 1/4"PLN (9/16" OD)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 2" Long)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 1" Long)
4 x Washers (Water Pump) 5/16"PLN (5/8" OD)
4 x Washers (Water Pump) 5/16"SPR (1/2" OD)
Thermostat (Short)
3 x Bolts 5/16 UNC (1/2" Head, 1 1/2" Long)
3 x Washers 5/16" SPR (1/2" OD)
Engine Electrical
2 x Bolts (Alt' top) 5/16"UNF (1/2" Head, 2" Long)
1 x Bolt (Alt' Bottom) M8x20
1 x Nut (Alt' Bottom) mate NyLoc
4 x Washers (Alternator) 5/16"PLN (5/8" OD)
4 x Washers (Alternator) 5/16"SPR (1/2" OD)
2 x Nuts (Alternator) 5/16"UNF (1/2" Head)
2 x Bolts Starter Motor 3/8"UNC (9/16" Head, 1 1/4" Long)
2 x Washers Starter motor 3/8"SPR (5/16" OD)
1 x Bolt (A+ Distributor) 5/16" UNF (1/2" Head, 3/4" Long)
Clutch Slave (Non verto)
2 x Bolts (Cyl Mount) 3/8"UNC (9/16" Head, 1" Long)
2 x Washers (Cyl Mount) 3/8"SPR (5/8" OD)
1 x Bolt (Arm Stop) 1/4"UNF (7/16" Head, 1" Long)
1 x Lock Nut (Arm Stop) 1/4"UNF (7/16" Head)
Clutch Cover
8 x Bolts 5/16"UNC (1/2" Head, 1" Long)
8 x Washers 5/16"SPR (1/2" OD)
8 x Washers 5/16"PLN (5/8" OD)
Tappet Chest
2 x Bolts 5/16" UNF (1/2" Head, 1 1/4" long)
2 x Washers 5/16 PLN (5/8" OD)
Pre A+ Distributor Drive
1x Bolt 1/4"UNF (7/16" Head, 3/4" long)
1x Washer 1/4"SPR (3/8" OD)
Fuel Pump 2 x Bolt 5/16" UNC (1/2 Head , 1 1/2"long)
2 x Washers 5/16" SPR (1/2" OD)
2 x Washers 5/16" PLN (5/8" OD)
Oil Filter Housing
2 x Bolt 3/8" UNC (9/16" Head, 1" Long)
2 x Washers 3/8" SPR
2 x Washers 3/8"PLN (15/16" OD)
Manifold Bolts
6 x Bolt 5/16 UNF (1" Long)
6 x Washers 5/16" SPR (1/2" OD)
6 x Washers 5/16" PLN (5/8" OD)
Timing Cover
Coolant Circui
Thermostat (Short)
Engine Electrical
Clutch Cover
Tappet Chest
Oil Filter Housing
Manifold Bolts
Re: Passos das roscas
o Pedro encontra cada coisa
Muito bom Pedro, já precisei disto muita fez...
Broa- Mensagens : 109
Data de inscrição : 02/05/2009
Tradução
TPI - Threads per inch - fios de rosca por polegada
Diametro (imperial) fios de rosca por polegada Diametro (metrico)
bolt - parafuso (head - cabeça, long - comprimento)
washer - anilha (PLN - chapa, SPR - mola)
nut - porca
ex
2x parafusos torneira aquecimento - 6.35 mm 28 fios de rosca (cabeça 11.11 mm, comprimento - 12.7 mm)
polegadas | passo de rosca UNC | Passo de rosca UNF | mm |
1/4 | 20 | 28 | 6.3500 |
5/16 | 18 | 24 | 7.9375 |
3/8 | 16 | 24 | 9.5250 |
7/16 | 14 | 20 | 11.1125 |
1/2 | 13 | 20 | 12.7000 |
9/16 | 12 | 18 | 14.2875 |
5/8 | 11 | 18 | 15.8750 |
3/4 | 10 | 16 | 19.05 |
7/8 | 9 | 14 | 22.2250 |
1 | 8 | 14 | 25.4 |
nut - porca
ex
boas pessoal.
eu tenho la por casa umas folhas com tudo isso.
estou num curso de mecatronica e como tbm tenho de tornear, frezar ... tenho la algumas tabelas.
vou digitaliza-las e posta-las aqui. estao muito claras e muito elaboradas.
têm passos de rosca, diametros da broca indicado para furar...
espero que ajude. é bastante util
manumini- Mensagens : 46
Data de inscrição : 14/04/2010
manumini escreveu:boas pessoal.
entao ja temos aqui um gajo pra nos rectificar peças a bom preço
LuisPereira escreveu:manumini escreveu:boas pessoal.
seria com todo o prazer mas falta-me o torno em casa.
costumo levar para a escola e faço nos tempos livres.
boa... a ver este topico... lembrei-me... o mini é ingles... os ingleses tem um triliao de passos de rosca... o mini vem com passos ingleses? Ja não quero o mini.....
M Bento Amaral- Mensagens : 156
Data de inscrição : 16/02/2010
Fonix eu em certos sitios parti parafusos, furei e fiz rosca normal
E sabes quais são agora os sitos que tem rosca normal e rosca fina? =x
M Bento Amaral escreveu:E sabes quais são agora os sitos que tem rosca normal e rosca fina? =x
Pra que?
Qdo sairem voltam a entrar, se partirem passo o macho nas outras, é facil
por acaso ando á nora com isto dos passos... isso se eu chegar a uma casa de parafusos eles percebem isso é que para mim isso é chines
já agora os parafusos do plafonier também são desses?? tou a ficar com vontade de por uns autoroscantes não tarda
Xpto escreveu:por acaso ando á nora com isto dos passos... isso se eu chegar a uma casa de parafusos eles percebem isso é que para mim isso é chines
Se for um gajo novo no ramo tás lixado... LOL
Eu trabalho numa casa do genero a pouco tempo, e quando me aparecem la a pedir roscas maroscas até dou cabeçadas... lol e em polegadas nem comento!
